j92devils Posted July 28, 2009 Share Posted July 28, 2009 I'm considering buying this stereo to replace the stock one in my '96 ES300: http://www.crutchfield.com/p_130P4100UB/Pi...UB.html?tp=5684. Will this work since it has a built-in AMP? Do I need to uninstall the factory amp? Do I need something called 'preamp outputs'? Do I need a wire harness? Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted July 28, 2009 Share Posted July 28, 2009 Since this radio has a built in amp, there is no real reason to keep the factory amp. When I installed a radio on my 93, I purchased a harness adapter (makes for a much cleaner installation). And then bypassed the factory amp. If 14 watts a channel is enough for you needs, the stock wires are large enough to carry the current. You will need to purchase a schematic for your car. I would also strongly recomend soldering all connections, and using heat shrink tubing. If you are not comfortable using a soldering iron, I would recomend having the stereo installed professionally. Quote Link to comment Share on other sites More sharing options...
