Air In The Brake Lines.
indivet
Hi Guys,
I have 98 ls 400. I replaced all rotors and brake pads. I was able to bleed left front and both rear wheels but I could not find the bleeder nipple on right front wheel. So I still has air in the brake system. I had maintenance manuals which I lost in recent move. Has anybody encountered that problem? Any Help will be appreciated.
Thanks
Jag
If you cannot find the bleed nipple someone has probably broken it off in the past.
You could try loosening the brake pipe/hose to the caliper and bleeding from there with someone to help.
