Cam Cover Gasket Change
Its not hard but it is time consuming because the throttle body has to be removed and the the Y pipe as well...............I had to remove the EGR pipe, some have done it without removing the EGR but I dont know how. If you look on clubna-t.com there is a down loadable manual on there I posted up. I'm pretty sure it is against the rules to post it here or else I would, mods if it is ok for me to post manual here let me know.
There is a good amount to changing these so typing out directions would take forever.
Thanks... I started to take all of that off, but thought maybe there was an easier way. Doesn't look like the the manifold has to be removed.
