04 Es330 Transfer Case Leak
Bought this car about a year ago with 46,000 miles. Had first leak at about 50,000 mi, dealer replaced gasket, had second leak a month later, (both had spots on garage floor) gasket replaced, now has third leak at 58,000 miles discovered at oil change and 60m mile maintenance (no noticeable leak on garage floor). Again gasket replaced, will have checked again in a month. Dealer said they checked the pan for roundness and it was ok. What would be the next step if it happens again and should this be a long-term concern?
Thanks all.
JudysES330
Is it a transmission leak? The ES330 doesn't have a transfer case...
The work order says "upon inspection found the transfer case to be leaking". The part they replaced says "369111 Auto Trans Oil Pan &/or gskt" so assume transmission but clearly says transfer case
