US SPEC
what is the chassis code for the is300?
what is the engine code for the is300?
will all the parts on an altezza fit the is300 besides the engine of course i know does not.
Jspec s200
this is what i found so far...i think this is the altezza codes...??
there is a SXE10 S3-GE
there is a GXE10 1G-FE
and engine... i think this is the supra engine...??
JZA80 SJZ-GE
um... SJZ-GTE
last question...
i read that because is300 USPEC has a supra nonturbo engine with weaker internals....this results in not having to buy lexus parts for the car. bc supra parts fit and they are cheaper? every engine part fit perfectly?
to get the turbo from a supra...id prolly have to build the engine up to par right?
and also probably need some custum piping to fit the is300 body rather than the supra body right?
thanx IS300 experts here is a tricky one.
US SPEC
Jspec s200
JZA80 SJZ-GE
um... SJZ-GTE
last question...
i'll take one of ur questions . The engine is actually 2JZ-GE as compare to the supra which is 2JZ-GTE. To build an engine that can handle the same power as a GTE., yes, u'll need the TT internals. A few ppl have done the conversion and in fact One of our members is in the process of doing the conversion. i suggest u go through his post. i'll try to find it for u.
