Clarity About S-afc In A 95 Sc300
I've reached the point of install, ready to set it up and fire up the car . . .
Then conflicting data occurs to me!
Apexi's website says my car is a "Pressure-3" sensor, while several write-ups around the net will back this up, or suggest its a Karman sensor.
Before I blow up my car, someone advise me;
What the hell settings do I need? 1995 Lexus SC300 n/a auto
thanks (and I did search)
*EDIT*
At this point I have verified that neither Karman or Hot Flap (sensor settings) work in any regard. On the recommended "Pressure 3in/3out" I have to gas a bit and let go of the key before it fully fires, and with that I get a choppy idle around 1k. If I touch the accelerator, even so slightly, it bogs and starts to kill itself. I have tried other settings / sensors and that was the only combination that came close to working.
Re-did all the wires from start, still nothing.
Removed the SAFC, car runs perfectly.
Anyone . . . please?
The goal is to thin down in the early RPMs (it especially likes to bog with custom 3" exhaust, no cats) and let it continue to scream in the top end; otherwise balance out the fuel delivery for all kinds of driving.
*end of edit*
-greg
