Sbca4mi Posted June 10, 2009 Share Posted June 10, 2009 Alright so i just took the plugs out to replace them on the front bank and they are pitch Black and are wet with raw fuel. I have no clue what could be causing this can someone please shead some light on this i need to get this car running asap!!! Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted June 10, 2009 Share Posted June 10, 2009 have you checked for spark yet? that would be a good step to take next. Quote Link to comment Share on other sites More sharing options...
Sbca4mi Posted June 11, 2009 Author Share Posted June 11, 2009 have you checked for spark yet? that would be a good step to take next. Yes there is spark but the are soaked with un burned fuel Quote Link to comment Share on other sites More sharing options...
stcist2 Posted June 11, 2009 Share Posted June 11, 2009 was the vehicle in running condition? was it running poorly? if it was running it is possible that the mass air flow sensor is bad , O2 sensor bad , maybe even a clogged air filter... need more info , was the cel on ? defenatly need more info Quote Link to comment Share on other sites More sharing options...
Sbca4mi Posted June 11, 2009 Author Share Posted June 11, 2009 was the vehicle in running condition? was it running poorly? if it was running it is possible that the mass air flow sensor is bad , O2 sensor bad , maybe even a clogged air filter... need more info , was the cel on ? defenatly need more info Yes when i got the car it was in running condition but it ran horribly i got it to start and it ran for about a minute or so then i turned it off and couldn't get it to turn over again...the CEL was not on. When i had the car running for that brief period i could smell the fuel the plugs are black and wet with fuel i have never had a vehicle do this so i am stumped... Quote Link to comment Share on other sites More sharing options...
Sbca4mi Posted June 11, 2009 Author Share Posted June 11, 2009 So update even thought the CEL was not on i ran the codes anyway the only code comeing up is code 5 which is the MAP sensor what is it and where is it? Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted June 11, 2009 Share Posted June 11, 2009 Where did you find a code 5? I looked up in ALLDATA and MITCHELL ON DEMAND, and they both start the codes at 12. Are you sure that it is not code 14? There is no MAP (manifold air pressure) sensors on these cars. Quote Link to comment Share on other sites More sharing options...
Sbca4mi Posted June 11, 2009 Author Share Posted June 11, 2009 Where did you find a code 5? I looked up in ALLDATA and MITCHELL ON DEMAND, and they both start the codes at 12. Are you sure that it is not code 14? There is no MAP (manifold air pressure) sensors on these cars. Well this is where i found my information on the code the CEL only kept flashing 5 times... http://www.automotiveforums.com/t895988-93...tification.html Quote Link to comment Share on other sites More sharing options...
