mike napoli Posted June 8, 2009 Share Posted June 8, 2009 I have a 1995 check engine light where is on, Where is the connector and what type of reader is needed, I have a ocb II , Will that work , Also can I short somthing out and get it ...HELP,,, Thank's Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted June 8, 2009 Share Posted June 8, 2009 The connector is just to the left of the steering wheel. Your car is OBDII, so your scanner should work on it. Quote Link to comment Share on other sites More sharing options...
CUMan Posted June 9, 2009 Share Posted June 9, 2009 The connector (OBDII) is inside the fuse compartment, just to the right of the fuses. Quote Link to comment Share on other sites More sharing options...
JJohnson1970 Posted August 31, 2009 Share Posted August 31, 2009 The connector (OBDII) is inside the fuse compartment, just to the right of the fuses. I have a 1994 that has a check engine code and the part stores said they can't check the code for me? Is my ODB 11 also? Quote Link to comment Share on other sites More sharing options...
JJohnson1970 Posted August 31, 2009 Share Posted August 31, 2009 The connector (OBDII) is inside the fuse compartment, just to the right of the fuses. How can you check the code on a 1994 ES 300? Is a 1994 model ODBII? Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted August 31, 2009 Share Posted August 31, 2009 It is OBDII, so the same procedure as the 95 up. Perhaps the parts store was confused. OBDII had just started coming out in 94, most cars were still OBDI. Quote Link to comment Share on other sites More sharing options...
