jarris Posted June 6, 2009 Share Posted June 6, 2009 one day i was sitting in a drive thru at a bank talkin' on the celly. the vehicle beside me was having muffler issues or something. to loud to have my conversation, i decided to let the window up. upon doing so, i heard a loud pop and the window slowly slid back down into the door. when i got home, i removed the interior door panel to inspect the problem and all i found was a small piece of white plastic laying in the bottom crease of the door. the plastic was no larger than the head of a thumb tac and i couldn't see further inside the door to find the windows motor. i guess it's safe to assume there are more removable panels to the door considering you have to get to the windows motor some how. i'm used to working on hondas. i learned really quik that the LEXUS was designed to eliminate the handy man at home. but i am the handy man and i am at home... if you've had this problem and manage to fix it without the assistance of dealership intelect, give me some ideas, please, before i go outside and start taking the car apart. the window motor makes it's normal sound when i push the button, but hasn't any effect. i'm currently using a pair of grip pliers on the window track to hold the window up and its summer time. the A C dosen't work and its awful.:cries: Quote Link to comment Share on other sites More sharing options...
grnsc40095 Posted June 7, 2009 Share Posted June 7, 2009 jarris, This link/ DIY solution could fix your current problem. http://www.clublexus.com/forums/sc-400-300...-sc-models.html Quote Link to comment Share on other sites More sharing options...
jarris Posted June 9, 2009 Author Share Posted June 9, 2009 jarris, This link/ DIY solution could fix your current problem. http://www.clublexus.com/forums/sc-400-300...-sc-models.html thank you for the link. it most certainly pointed me in the right direction. :D Quote Link to comment Share on other sites More sharing options...
grnsc40095 Posted June 9, 2009 Share Posted June 9, 2009 jarris, Not sure if you had this DIY, but it will help tackle the window issue. http://www.clublexus.com/forums/lexus-audi...html#post802171 Quote Link to comment Share on other sites More sharing options...
