46Georgia Posted May 25, 2009 Posted May 25, 2009 New here need some advice. Have 2001 IS300 has moonroof .The personal light or map light switch is bad need to know where to buy the switch.Push button style on/off. Cant seem to find any information on it
1990LS400 Posted May 25, 2009 Posted May 25, 2009 New here need some advice. Have 2001 IS300 has moonroof .The personal light or map light switch is bad need to know where to buy the switch.Push button style on/off. Cant seem to find any information on it I'm guessing that you will have to buy the whole map light assembly and that the switches and buttons are not available separately ... that's what I had to do for my 00 LS since the switches were not available separately. Get the part number you need from: http://www.toyodiy.com/parts/p_U_2001_LEXU...EAVFA_8121.html Make sure you get the part number for the correct color. Then plug the part number into the search field here: http://www.parts.com/oemcatalog/index.cfm?...or&siteid=2 For example, the part number for an ivory color map light assembly for a 2001 IS300 with moonroof is 81260-32090-A2 Searching for part number 81260-32090-A2 on parts.com shows the ivory map light assembly is available at $102.38.
