Door Lock Problem?
ravig292
I had the same problem on my 1994 LS and that was due to the lock/unlock motor having failed ( brushes worn out), I would imagine it's similar on the 2000 model.
A lot of cars use solenoids for central locking but the LS is motor driven.
With yours being intermittant it may also be a wiring problem,give the rubber cover from the door to the door frame carrying the wiring loom a shake whilst operating the central locking and see if this affects the operation.
