I have an 04 RX 330. The black plastic trim pieces on the triangular side windows at the rear have blown off. My dealer told me this was common on the 04 and 05 models until a change was made in the design.
Instead of selling the trim piece (which is a snap on item with push pins, one must buy the entire window assy to get it (and then remove the old window and install and reseal the new one)..
Does anyone know of an aftermarket source for the trim piece only or of another fix? Thanks
Walter
Tucson AZ
Sorry about your situation. What a stupid approach for Lexus to handle what is simply a trim issue....
If you can't find the trim pieces through aftermarket sources or online Lexus parts sellers (some can be found right here as sponsors of this forum), try your local salvage yards....
  • 3 weeks later...
Walter
Tucson AZ
mine fell off going down the windy coast, you have any luck finding a replacement trim piece?
Walter
Tucson AZ
The trim piece on the passenger side fell/blew off. Our dealer replaced it for free since it was more of a design issue. You are correct in that you have to replace the entire window in order to replace the trim. They had to special order it. Took about a week. Have a 2004 RX330.
Cole
  • 5 weeks later...
Walter
Tucson AZ
Cole
Which dealer did you go to?
I bought my car at Lexus of Thousand Oaks and they basically told me I had to buy the whole window and have it installed.
Explained this was a pervasive problem, design flaw, etc. Was told "not anything I can do for you but replace the whole window at your expense".
  • 5 years later...
Its about time!!!! a replacement trim that can be installed on the existing window saving you time and a lot of money, I went to the dealership they wanted $186.30 for the whole window plus $125.00 in Labor to install it because they send it out to a glass shop add the with tax its way over
$300 bucks, I found these on e bay and installed them on my RX went on easy after following the instruction video thumbsup.gif
there is a video on YOU TUBE showing how it is installed
here is the link
https://youtu.be/iTrnA2-Mno4
it's available on e bay for only $65.00 plus shipping
just go to ebay and copy and paste this into your e bay search
Lexus RX rear quarter window trim for 04-09 RX330 RX350 RX400h
  • Like 1
