Can I use universal 7mm spark plug wires, ie. Mallory Blue or Accel? I noticed the OEM plug wires have the plastic extension and the tube seal integrated into the wire, but at $90 a set? I can get 25ohm/ft 8.8mm MSD wires for less than that and cut to fit. I figured if the tube seals were in the valve cover for oil control and the seals on the plug wires were only for the spark plug wells, I figured I could do without the well seals and just run the wires to the plug. Wire covers need not fit as I like the wires exposed. Thanks.
