c36wong Posted May 5, 2009 Share Posted May 5, 2009 Hello All, I was wondering if I will have any problems with using 235/65/17 on my RX300. Thanks! Quote Link to comment Share on other sites More sharing options...
pauljcl Posted May 5, 2009 Share Posted May 5, 2009 Hello All,I was wondering if I will have any problems with using 235/65/17 on my RX300. Thanks! I don't know what year your RX300 is, but mine has 16" wheels (tires are 225/70/16), so a 17" tire is surely the wrong size. Assuming you have 17" wheels, and assuming clearance is available, you might be interested in the following Website which gives you the tire size equivalencies or differences in circumference depending on the width/aspect ratio chosen: http://www.miata.net/garage/tirecalc.html It's pretty neat. Good luck! Quote Link to comment Share on other sites More sharing options...
Deepak Gandhi Posted May 5, 2009 Share Posted May 5, 2009 Hello All,I was wondering if I will have any problems with using 235/65/17 on my RX300. Thanks! I purchased a preowned RX330 that came with 235/65/17. That would tell me that yes you can use these tires. Deepak Quote Link to comment Share on other sites More sharing options...
c36wong Posted May 9, 2009 Author Share Posted May 9, 2009 Thanks for your responses. It is a 2001 RX300. I have steel rims with them, with the correct bolt pattern. I am just wondering if I will be having any clearance problem. It looks as if the rear suspension is awfully close to the oem tires... Please let me know if you have this size (235/70/17) installed on your RX300. Thanks! Quote Link to comment Share on other sites More sharing options...
