TroyLexus Posted April 15, 2009 Share Posted April 15, 2009 After driving for even 10 or 15 minutes or so, I can smell a distinct burnt oil smell. I read in the manual that these are supposed to burn SOME oil, but this seems a little much... any idea's ? any input ? Is this nothing to worry about ? is this an early sign this engine is junk ? 2004 / 80,000 miles. . . Thanks! Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted April 15, 2009 Share Posted April 15, 2009 It is probably the valve cover gaskets leaking oil, and it is making it's way down to the exhaust manifold. Look for the leak, and take care of it. Quote Link to comment Share on other sites More sharing options...
TroyLexus Posted April 15, 2009 Author Share Posted April 15, 2009 It is probably the valve cover gaskets leaking oil, and it is making it's way down to the exhaust manifold. Look for the leak, and take care of it. Is the valve cover gasket an easy fix ? what is the ballpark estimate for that from an indie shop? Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted April 15, 2009 Share Posted April 15, 2009 It's listed as about 3 hours, front gasket is very easy. rear gasket requires you to remove the intake plenum. Good time to consider changing spark plugs. Quote Link to comment Share on other sites More sharing options...
