pauljcl Posted April 11, 2009 Share Posted April 11, 2009 The 2009RX350 has a feature that I dislike: It resets to 0.0 the avge mpg computer whenever you fill the gas tank. It also has a 'reset to 0' feature that you can achieve by pressing on the 'info' switch. I like to measure consumption over a longer period, resetting it as I wish (which is how the 'old' RX300 worked). Does anyone know how to disable the 'reset to 0' feature when the gas tank is replenished? Quote Link to comment Share on other sites More sharing options...
data2009 Posted April 18, 2009 Share Posted April 18, 2009 The 2009RX350 has a feature that I dislike: It resets to 0.0 the avge mpg computer whenever you fill the gas tank. It also has a 'reset to 0' feature that you can achieve by pressing on the 'info' switch. I like to measure consumption over a longer period, resetting it as I wish (which is how the 'old' RX300 worked). Does anyone know how to disable the 'reset to 0' feature when the gas tank is replenished? I may be wrong, but I think the trip computer shows both. If you scan through functions, one shows the total average mpg, and another shows average mpg since last fill up. Quote Link to comment Share on other sites More sharing options...
pauljcl Posted April 18, 2009 Author Share Posted April 18, 2009 The 2009RX350 has a feature that I dislike: It resets to 0.0 the avge mpg computer whenever you fill the gas tank. It also has a 'reset to 0' feature that you can achieve by pressing on the 'info' switch. I like to measure consumption over a longer period, resetting it as I wish (which is how the 'old' RX300 worked). Does anyone know how to disable the 'reset to 0' feature when the gas tank is replenished? I may be wrong, but I think the trip computer shows both. If you scan through functions, one shows the total average mpg, and another shows average mpg since last fill up. TKs. for replying - I'll check it out. I thought it only offered 'instantaneous' mpg, avge. mph, range.... and of course avge mpg (since last refill). Quote Link to comment Share on other sites More sharing options...
pauljcl Posted April 19, 2009 Author Share Posted April 19, 2009 The 2009RX350 has a feature that I dislike: It resets to 0.0 the avge mpg computer whenever you fill the gas tank. It also has a 'reset to 0' feature that you can achieve by pressing on the 'info' switch. I like to measure consumption over a longer period, resetting it as I wish (which is how the 'old' RX300 worked). Does anyone know how to disable the 'reset to 0' feature when the gas tank is replenished? I may be wrong, but I think the trip computer shows both. If you scan through functions, one shows the total average mpg, and another shows average mpg since last fill up. No: The trip computer for avge mpg always resets when filling up the tank. A 'wild guess' is that it is because that is what is used to calculate 'range': so, when the volume of gas changes, the ranges changes and they (i.e. Lexus) set it to conform to the most up-to-date consumption pattern. Too bad..... Quote Link to comment Share on other sites More sharing options...
