How To Take Out License Plate Lights
ravig292
1. Take the cover off with a phillips screw driver....
2. Pull out the 194...
Unless something has been drastically changed on the 98-00 It's as simple as 1, 2, done.
You should get LED replacements B)
www.superbrightleds.com
yea thats what i'm thinking. i want to get white ones like they have in the new Lexus models.
Hello from Calgary. The license plate lights seem so simple...however...after removing the 4 Phillips screws the 2 little plastic covers over the bulbs refuse to come off. This is a '93 LS400 with 258,000 kms on it. I'm afraid to force the little "windows" as they'll probably break easily. I will try spraying with WD-40 in case that loosens them and allows the windows to fall out.
Anyone have a better suggestion?
You botched the quote B) lol
And there are little "snap" kind of fittings on the lenses.
Take a small flat head screwdriver, and just pry on it very gently and you'll be able to see where the snaps are.
They pull right out.
