Brick Guy Posted April 2, 2009 Share Posted April 2, 2009 Where is the fuel filter on a 2000 LS400? I have 130,000 miles and it is original. Yesterday it started then stopped and would not restart. After sitting and a lot of cranking it finally started. This repeated another time. All of this while parked in my garage. I am wondering if the fuel filter needs replacement? Not sure where it is located. Quote Link to comment Share on other sites More sharing options...
Marklouis Posted April 2, 2009 Share Posted April 2, 2009 Where is the fuel filter on a 2000 LS400? I have 130,000 miles and it is original. Yesterday it started then stopped and would not restart. After sitting and a lot of cranking it finally started. This repeated another time. All of this while parked in my garage. I am wondering if the fuel filter needs replacement? Not sure where it is located. did your check engine light come on? if so i would find a way to get a diagnostics done, whether you rent the tool from an auto parts store or borrow from someone...that should be your first step. Did you just fill up with gas? where there any symptoms before this occurance? The Fuel Filters are a lifetime design, so if you decide to replace it, make certain that is your issue. good luck on the venture!! :) Quote Link to comment Share on other sites More sharing options...
Brick Guy Posted April 2, 2009 Author Share Posted April 2, 2009 Where is the fuel filter on a 2000 LS400? I have 130,000 miles and it is original. Yesterday it started then stopped and would not restart. After sitting and a lot of cranking it finally started. This repeated another time. All of this while parked in my garage. I am wondering if the fuel filter needs replacement? Not sure where it is located. No check engine warning or lights came on. Started great this morning. Maybe a can of sea foam and fill up would help. Currently half full of gas. Quote Link to comment Share on other sites More sharing options...
Lucky13 Posted April 2, 2009 Share Posted April 2, 2009 its under the car. Look under and follow the conduit leading from the tank on the left side toward the front. Quote Link to comment Share on other sites More sharing options...
