Bk4293 Posted March 19, 2009 Share Posted March 19, 2009 Hey guys, just saved an older ES 300 from being towed and she needs new shoes pretty bad. I tried searching, and from what I read the tires and offset might be an issue but I figure I'd check anyway since all these offsets and tire sizes and stuff hurt my puny little brain.... Here's the info, I really wanna find her some good shoes so I can actually start to drive her around (picked her up with two flat tires)... toyota/lexus 17x7.5 wheels&tires - $500FOR SALE IS A SET OF 17X7.5 RIMS MADE BY RTK WHEELS WITH A 5X114 BOLT PATTERN WITH A 48MM BACK SPACING.THEY HAVE 245X45X17 TIRES BY NAKOOK THESE WHEELS AND TIRES HAVE LESS THAN 2000 MILES ON THEM CAME OFF A LEXUS SC300.THESE WHEELS WILL FIT ANY LEXUS,TOYOTA,FORD,MAZDA,AND HINDA WITH A FIVE LUG PATTERN. Quote Link to comment Share on other sites More sharing options...
DUBBCEE Posted March 19, 2009 Share Posted March 19, 2009 Those Wheels are for a rear wheel drive car. They will not fit. Hey guys, just saved an older ES 300 from being towed and she needs new shoes pretty bad. I tried searching, and from what I read the tires and offset might be an issue but I figure I'd check anyway since all these offsets and tire sizes and stuff hurt my puny little brain....Here's the info, I really wanna find her some good shoes so I can actually start to drive her around (picked her up with two flat tires)... toyota/lexus 17x7.5 wheels&tires - $500FOR SALE IS A SET OF 17X7.5 RIMS MADE BY RTK WHEELS WITH A 5X114 BOLT PATTERN WITH A 48MM BACK SPACING.THEY HAVE 245X45X17 TIRES BY NAKOOK THESE WHEELS AND TIRES HAVE LESS THAN 2000 MILES ON THEM CAME OFF A LEXUS SC300.THESE WHEELS WILL FIT ANY LEXUS,TOYOTA,FORD,MAZDA,AND HINDA WITH A FIVE LUG PATTERN. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted March 19, 2009 Share Posted March 19, 2009 The offset mentioned is a FWD one and it will fit fine even if it wasn't. Quote Link to comment Share on other sites More sharing options...
blk_on_blk Posted March 19, 2009 Share Posted March 19, 2009 Yep, they should fit, but I would check to see how they fit with that offset. The overall offset range for the ES300 is +35 to +50, and you're bumping up on the limit with a +48, but they'll fit. You just may want to check and see how they fit and if it's a proportion you like. Quote Link to comment Share on other sites More sharing options...
Bk4293 Posted March 19, 2009 Author Share Posted March 19, 2009 Yep, they should fit, but I would check to see how they fit with that offset. The overall offset range for the ES300 is +35 to +50, and you're bumping up on the limit with a +48, but they'll fit. You just may want to check and see how they fit and if it's a proportion you like. I wonder if he'll let me test fit one or two before I actually buy them. I was also worried about tires rubbing being a 245 series Quote Link to comment Share on other sites More sharing options...
blk_on_blk Posted March 19, 2009 Share Posted March 19, 2009 I'm sure he would. I would if I were selling them. Quote Link to comment Share on other sites More sharing options...
