I sent this earlier but have further information. The car has been in the garage since last night and went out this morning to check once again and everything is working. The only thing I can think of is that it has been raining here and it is attributed to something getting wet ....since it dried up in the garage. What could be getting wet that would cause this?
Thanks
Hello, hoping I can get some advice. My GS 300 has a problem where only the driver side door window will work but the other three dont. In addition to that the steering column adjustment does not work and also the automatic headlights coming on or off. Would anyone have any ideas? It worked before yesterday but all of the sudden this happened.
I appreciate any help
Thanks,
Joe
Thanks
Thanks,
Joe
well joe,
you could have many things going on....you could have a small leak, your sunroof drain could be clogged, your a/c system could be leaking, your heater core could have a leak... could be leaking onto a fuse box and maybe thats why some of your electrical problems arent working....do you know where the leaking is coming from? might try running a water hose over car and seeing it leaks or try a carwash or then try the a/c system. good luck sir...keep us updated
Thanks
Thanks,
Joe
well joe,
Thanks ....I will have to do that since the problem has not repeated, I am convinced that it has to do with something getting wet. I will try your suggestion and see if I can get it to happen again.
