rg1 Posted March 2, 2009 Share Posted March 2, 2009 Im going to be undergoing this project based on GoldenStateSilverSport's post http://us.lexusownersclub.com/forums/index...723&hl=IACV I did see a few mentions in other posts about the EGR and the TPS and wondering if I should be concerned about it. I would like to clean the EGR, however not sure where it is same with the TPS (not sure if my model has the TPS). I saw the warnings about the cleaning fluids and to use non 02 sensor damaging stuff. I also did see the warnings about the tight screws from the factory, so I will be watch out for that. Is there anything I should be concerned with? Thanks in advance. Just shelled out $1500 for the 90K service, timing belt, water pump and cam/crank seals. Looking forward to getting down and dirty, and then clean and saving some flow of course... :) Cheers -Rob Quote Link to comment Share on other sites More sharing options...
lenore Posted March 2, 2009 Share Posted March 2, 2009 I dont believe you have an EGR, I have a 99 RX300 and mine doesnt have that. EGR is controlled through VVTI on this engine... Quote Link to comment Share on other sites More sharing options...
rg1 Posted March 2, 2009 Author Share Posted March 2, 2009 I dont believe you have an EGR, I have a 99 RX300 and mine doesnt have that. EGR is controlled through VVTI on this engine... Thanks for the reply. Quote Link to comment Share on other sites More sharing options...
