rtbshome Posted March 2, 2009 Share Posted March 2, 2009 First of all many thanks to owners who have contributed over the years. I have gleaned too much to mention. Current problem with a 94 LS400 180K miles is that I am getting regular every few minutes voltage surges. Fan speeds up, lights get bright, battery light illuminates for a few seconds then drops back to normal. Digital voltage (cigarette lighter) reads 14-14.4 then soars past 16. I rebuilt the power steering pump last August and replaced the alternator with a rebuilt at that time. Every thing is dry underneath, removed the battery connections and cleaned and reinstalled (battery is less than a year old). I also checked the trunk hinge wires, but found no broken wires there. I ran the car and from underneath tried jiggling the alternator connections but the problem doesn't seem to happen very often at idle, either way I couldn't induce the voltage change from moving the wires. I am stumped, I have another alternator coming in tomorrow, but would like to make sure I don't have another problem first. Suggestions please. Thanks Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted March 2, 2009 Share Posted March 2, 2009 First of all many thanks to owners who have contributed over the years. I have gleaned too much to mention. Current problem with a 94 LS400 180K miles is that I am getting regular every few minutes voltage surges. Fan speeds up, lights get bright, battery light illuminates for a few seconds then drops back to normal. Digital voltage (cigarette lighter) reads 14-14.4 then soars past 16. I rebuilt the power steering pump last August and replaced the alternator with a rebuilt at that time. Every thing is dry underneath, removed the battery connections and cleaned and reinstalled (battery is less than a year old). I also checked the trunk hinge wires, but found no broken wires there. I ran the car and from underneath tried jiggling the alternator connections but the problem doesn't seem to happen very often at idle, either way I couldn't induce the voltage change from moving the wires.I am stumped, I have another alternator coming in tomorrow, but would like to make sure I don't have another problem first. Suggestions please. Thanks Check the voltage regulator. Quote Link to comment Share on other sites More sharing options...
rtbshome Posted March 2, 2009 Author Share Posted March 2, 2009 The regulator is integrated in the alternator, I am trying to figure out if other factors can cause these symptoms prior to replacing it. Quote Link to comment Share on other sites More sharing options...
