The1 Posted February 27, 2009 Share Posted February 27, 2009 My friend has a 93 camry and i figured since they are similar someone might be able to help me help her. The only time the tail light works is if you are using the brakes, theres only two parts on the far ends that will light up while the lights are on. Thanks for any help Quote Link to comment Share on other sites More sharing options...
motoroil Posted February 27, 2009 Share Posted February 27, 2009 I used to have a '95 Mazda MX3 that did that, never figured out how to fix it. Interestingly, on my MX3 the tailight fuse always blew also when you started the ignition, and the tailights would always work when braking, even with the blown fuse, but never unless I was braking. I even tried putting in a higher-rated fuse, which never blew, but the lights still only lit up when using the brakes. It'll drive ya nuts! Quote Link to comment Share on other sites More sharing options...
The1 Posted February 28, 2009 Author Share Posted February 28, 2009 It is mechanics have looked at it and it makes them crazy. Quote Link to comment Share on other sites More sharing options...
