I recently swapped out my instrument cluster myself (after the mechanic had royaly screwed over my original one). And the temperature gauge reads about 25% instead of resting at the bottom so when It runs to optimal temperature it will move up half of the gauge to about 75%. Basically its like the gauge was bumped up a bit. I wanted to know if there is a way to move it down via a Tension screw or if you can adjust/reset it via lightly pulling the needle out and reseting it like you can do with the tachometer and speedometer. Thanks in advance.
