Looking for good replacement part links for the evap canister on an RX300. Am at 121K and got a ck engine on it. Is aftermarket working for anyone? appreciate the head start. looks like a bear to replace for a DIY gal.
Are you sure you need a canister? It is a common occurrence that during an oil change someone opens the air box to check the air filter. When lifting the top of the air box it is very easy to disconnect the evap hose from the metal tube located behind and below the air box directly under the brake fluid container. This will give a evap type code with a CEL.
