Help Me Out
dodgemaniac
Pulling the rear seat is pretty easy, once you have it out there is a cover over the hole that has to be removed, and even then I don't think the hole is larger than the trunk opening. To remove the seat, first remove bottom seat by pulling up on the front of the bottom, it will come loose.The rear seat back is held on by two bolts on either side and hooks across the back. Once the bolts are removed lift the back right up to disengage the hooks across the back. Once the seat is removed there is a metal and fiberboard cover that must me removed both from the cabin side and from the trunk side. Good luck....
Cqpn
