deeps30 Posted February 19, 2009 Share Posted February 19, 2009 Hi, I have a 2004 RX 330. Recently, when I turn on the heat (not defroster), I get this burning, smelly smell for the first couple of minutes when the heater is running. After the heater runs for a few minutes, the smell disappears. Anyone have experience with this and a solution. My local guy thinks it may be time to replace the cabin filter but not sure. Thanks. Deepak Ontario, Canada Quote Link to comment Share on other sites More sharing options...
Deepak Gandhi Posted February 20, 2009 Share Posted February 20, 2009 Hi,I have a 2004 RX 330. Recently, when I turn on the heat (not defroster), I get this burning, smelly smell for the first couple of minutes when the heater is running. After the heater runs for a few minutes, the smell disappears. Anyone have experience with this and a solution. My local guy thinks it may be time to replace the cabin filter but not sure. Thanks. Deepak Ontario, Canada I heard someone else say the same and then he realized that the problem was with the seat heaters. Unfortunately I do not know what happened next. Regards Deepak Gandhi Quote Link to comment Share on other sites More sharing options...
Craig M Posted February 27, 2009 Share Posted February 27, 2009 Hi,I have a 2004 RX 330. Recently, when I turn on the heat (not defroster), I get this burning, smelly smell for the first couple of minutes when the heater is running. After the heater runs for a few minutes, the smell disappears. Anyone have experience with this and a solution. My local guy thinks it may be time to replace the cabin filter but not sure. Thanks. Deepak Ontario, Canada Check your valve cover gaskets for leaks. We had the same problem in ours, oil was leaking onto the exhaust manifold at startup. Quote Link to comment Share on other sites More sharing options...
AznMechanic Posted March 1, 2009 Share Posted March 1, 2009 Hi,I have a 2004 RX 330. Recently, when I turn on the heat (not defroster), I get this burning, smelly smell for the first couple of minutes when the heater is running. After the heater runs for a few minutes, the smell disappears. Anyone have experience with this and a solution. My local guy thinks it may be time to replace the cabin filter but not sure. Thanks. Deepak Ontario, Canada I had the similar experience with my car as well. Mine smelled like dog/nasty smell. I took it to the dealer and told me theres moisture in the cabin air filter. Their price quote was $100+tax!!! I was like psh yeah right so i ordered it online and changed it myself and the smell kind of went away but I read some posts and my smell might have mold inside the system Anyways changing the cabin air filter might help a lot and check if its dirty when you take it out and smell it and see if the cabin air filter smells. If that doesnt work give me a reply and ill get back to you. :D Quote Link to comment Share on other sites More sharing options...
