nfinite Posted January 30, 2009 Share Posted January 30, 2009 I think i blew up the fuse by connecting the batter otherway round.It doesn't start anymore nor central locking work.Which fuse could it be i checked small ones under the drivers side foot panel and also next to the battery.Could it be one of the big ones?Or is it located elsewhere? Quote Link to comment Share on other sites More sharing options...
BillyShaft Posted January 30, 2009 Share Posted January 30, 2009 Probably blew one of the big ones. If you are lucky... Quote Link to comment Share on other sites More sharing options...
TexasLexus94 Posted January 30, 2009 Share Posted January 30, 2009 "Sounds like the big 120A alternator fuse that is in the fuse box under the hood. Did you check it? " This is a quote from Blake, who responded to another recent request with a similar problem. I blew the fuse working on the ACV on the P/S pump. Didn't disconnect the battery-Duh. The fuse cost me around $15 at a Toyota dealer. Best of luck. Quote Link to comment Share on other sites More sharing options...
nfinite Posted January 30, 2009 Author Share Posted January 30, 2009 "Sounds like the big 120A alternator fuse that is in the fuse box under the hood. Did you check it? "This is a quote from Blake, who responded to another recent request with a similar problem. I blew the fuse working on the ACV on the P/S pump. Didn't disconnect the battery-Duh. The fuse cost me around $15 at a Toyota dealer. Best of luck. Found it!Thanks a lot. Quote Link to comment Share on other sites More sharing options...
BillyShaft Posted January 30, 2009 Share Posted January 30, 2009 Awesome! Was there any other electronics damage, or did the fuse save you? Quote Link to comment Share on other sites More sharing options...
nfinite Posted January 31, 2009 Author Share Posted January 31, 2009 . Quote Link to comment Share on other sites More sharing options...
doanh Posted September 11, 2013 Share Posted September 11, 2013 I am curious to the conclusion of this discussion.. Was it just the main fuse? I know it's kinda old Quote Link to comment Share on other sites More sharing options...
steve2006 Posted September 11, 2013 Share Posted September 11, 2013 I managed to blow mine also working on the PS pump recently and yes it was just the 120A fuse in the engine compartment fuse box. The fuse is not just a straight plug out and in type it is also bolted in which require the removal of the fuse box section it is located in and then uncliping the covers on either side to get access to the bolts. Main thing is to remember to disconnect the battery this time! Quote Link to comment Share on other sites More sharing options...
