Well Question, Please A Little Help
:huh: Do you guys think 19x8.5 will clear my 09' IS 250? Thanks in advance people.
Yes. The size isn't really the issue so long as your not changing the outside diameter of the tire. It's more about the offset and if you lower the suspension. Most aftermarket wheels companies do "general" measurements. In other words. XX offset will fit XX different cars without rubbing or caliper clearance issues. Unless your looking for "aggressive" wheel setups, you'll be fine.
