radelman33 Posted December 29, 2008 Share Posted December 29, 2008 Does someone have instructions on replacing the two accessory belts? What skill level is required? 2003 ES 300 Thanks. Quote Link to comment Share on other sites More sharing options...
steviej Posted December 30, 2008 Share Posted December 30, 2008 Does someone have instructions on replacing the two accessory belts? What skill level is required? 2003 ES 300Thanks. The easiest way is to remove the right front tire and the wheel well splash guard, then it is pretty self explanatory. The only reason I would take it to a mechanic is to get the proper belt tenison right. These don't have spring loaded belt tensioners that keep a constant variable pressure on the belt. They have to tension the belts up by moving the accessories. steviej Quote Link to comment Share on other sites More sharing options...
radelman33 Posted January 1, 2009 Author Share Posted January 1, 2009 Can anyone explain how the tension system works on the power steering belt? Is there a pivot bolt and then you have to manually force the power steering pump to tighten it? How do you keep it tight? Quote Link to comment Share on other sites More sharing options...
