Front Radiator Resevoir Leak
I have a 1992 SC400 and I noticed the last two months or so, the rubber black cap on the radiator resevoir is leaking around the seal. I noticed wen I pryed it up it had 2 small wires going through it. Is this to let the cluster know when the coolant is low? Also is there a permanent cheap fix?
