Shadowlex Posted December 20, 2008 Share Posted December 20, 2008 Hello Everyone: I lost my headlights suddenly on my 1995 sc 400. My left turn indicator made some electric buzzing sound when I pressed down to set in the left turn signal. Is there any connection between the column switch and the headlights. I have not checked the bulbs yet. thanks! Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted December 20, 2008 Share Posted December 20, 2008 Welcome to the club. I doubt you would have blown both headlight bulbs at the same time. Have the headlight relay tested. If that checks out, then check the switch. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted December 20, 2008 Share Posted December 20, 2008 BTW, I see you've posted this topic twice. Please stay with one thread per topic, otherwise it makes it difficult for readers to follow the thread. If you get no response to your initial posting, just post again, but in the same thread. Quote Link to comment Share on other sites More sharing options...
Shadowlex Posted December 20, 2008 Author Share Posted December 20, 2008 BTW, I see you've posted this topic twice. Please stay with one thread per topic, otherwise it makes it difficult for readers to follow the thread. If you get no response to your initial posting, just post again, but in the same thread. Quote Link to comment Share on other sites More sharing options...
Shadowlex Posted December 20, 2008 Author Share Posted December 20, 2008 Welcome to the club. I doubt you would have blown both headlight bulbs at the same time. Have the headlight relay tested. If that checks out, then check the switch. Quote Link to comment Share on other sites More sharing options...
Shadowlex Posted December 20, 2008 Author Share Posted December 20, 2008 thanks for your help; any ideal what this owuld cost? Quote Link to comment Share on other sites More sharing options...
Shadowlex Posted December 20, 2008 Author Share Posted December 20, 2008 I got ahead of myself; I check the blade and cartridge fuses; they seem to be okay. Where do I find the relays? How can I tell if the relay is blown? thanks again. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted December 22, 2008 Share Posted December 22, 2008 Not sure if they've moved the relays in the 95, but on my 91 they're in the engine compartment in a black JB just behind the coolant expansion tank. On the underside of the cover should be a diag labelling all the relays similar to what I've attached: You'll need a multi meter to test the continuity between the pins. I don't have a diag of the pins or the readings you should get. Service dept at your dealer should be able to test it for you or at the least give you a diag and the specs. Quote Link to comment Share on other sites More sharing options...
