leksus430 Posted December 17, 2008 Share Posted December 17, 2008 Hi,i got this problem this year, when i put on heat it blows cold air for ten minute and its not blowing hot air until i start driving for awhile,does anyone have the same problem,what can it be?thanks Quote Link to comment Share on other sites More sharing options...
Will B. Posted December 18, 2008 Share Posted December 18, 2008 Every car I've ever driven has done this - it takes time to heat up air. If you leave the climate control set to auto, it will not blow out air until it is heated. I prefer this to being blasted with cold air, so I leave mine to auto. Quote Link to comment Share on other sites More sharing options...
leksus430 Posted December 21, 2008 Author Share Posted December 21, 2008 Hi,i got this problem this year, when i put on heat it blows cold air for ten minute and its not blowing hot air until i start driving for awhile,does anyone have the same problem,what can it be?thanks Fixed it,just needed to add antifreeze,it blows hot air again Quote Link to comment Share on other sites More sharing options...
90LS400Lexus Posted December 21, 2008 Share Posted December 21, 2008 The coolant was low? Is it leaking somewhere? Quote Link to comment Share on other sites More sharing options...
leksus430 Posted December 24, 2008 Author Share Posted December 24, 2008 The coolant was low? Is it leaking somewhere? No,its not leaking,i just never check since i got,simply because you got to unscrew the top plastic to see the coolant leve Quote Link to comment Share on other sites More sharing options...
