pcroland Posted December 30, 2003 Share Posted December 30, 2003 Hey all, I have a little problem here, dunno if anyone can help ... I have a '93 Gs300 and locked the main switch(pushed it in) between the Gas tank and trunk releases ... problem is, I only received one key with the car ..I believe this is the valet key since there is no keyless entry button on it ...and it won't unlock the switch, and since the previous owner had removed the trunk lock from the lid, I have no way of getting in the trunk now! :D I appreciate any suggestions. Roland Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted December 31, 2003 Share Posted December 31, 2003 I don't mean to sound like an !Removed!, but the solution is obvious. Go to a dealer and get a master key. Open the trunk button lock. While you're there, get the trunk lock fixed. Perhaps expensive, but it won't happen to you again. Quote Link to comment Share on other sites More sharing options...
pcroland Posted December 31, 2003 Author Share Posted December 31, 2003 ...I was just reading on one of the forums that in order to program a new master key( if i was to get one from the dealer), i'd need to have at least one programmed master key already. ... and it seems the only other solution, without any master keys presently, is to change some computer which costs around $2,000 Quote Link to comment Share on other sites More sharing options...
bbsal Posted December 31, 2003 Share Posted December 31, 2003 if you go to the dealer they can make you the key.i dont think you need a master hey in order for them to make you one.check and call your local dealer but im pretty sure it wont cost near that much! Quote Link to comment Share on other sites More sharing options...
pcroland Posted December 31, 2003 Author Share Posted December 31, 2003 Thanks alot all, i'll go ahead and get the master key. Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted January 1, 2004 Share Posted January 1, 2004 You need one key that starts the car to make additional keys. The valet key has a chip and is programmed for your car. Go ahead, bite the bullet, and give up the $$$ to the dealer. You'll be glad you did. Quote Link to comment Share on other sites More sharing options...
