I had a bulb and its wire shake loose from the driver's side front side bumper yellow reflector/light on my 2001 IS300. A mechanic reinserted the bulb into its holder, and it works just fine. But the warning light indicating a bad bulb is still on. I've checked all lights, and they all work. Does anyone know how to reset the warning light, or if it can be done? Thanks.
Disconnecting the negative battery terminal for about 10 minutes will usuallly reset everything.
I had to do that when a light came on from having the gas filler cap off.
