lexus400 Posted October 28, 2008 Share Posted October 28, 2008 I'm trying to remove my shifter to clean up after a spilled drink. I removed the screw on the right side. Does it have to be in a certain position to come off? I tried pulling the shift button out which works on some other cars. thanks, Bob Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted October 28, 2008 Share Posted October 28, 2008 What screw? The middle woodgrain piece should just pop right out. You might need to provide a lot more detailed info of where you removed a screw, and what you've taken off already, and what you're trying to remove. Quote Link to comment Share on other sites More sharing options...
lexus400 Posted October 29, 2008 Author Share Posted October 29, 2008 I already removed the woodgrain insert and shifter surround. On the right side of the shifter, there's a plug which covers a philips screw. I removed that but the shifter doesn't come off. Just to be clear, I'm trying to remove the shifter itself (what your hand goes on). thanks, Bob Quote Link to comment Share on other sites More sharing options...
fsuguy Posted April 8, 2009 Share Posted April 8, 2009 Hi Guys, I am hoping for some more info on this shifter thing! My '92 shifter is really sloppy and also the light underneath is intermittent - I think I have a short under there somewhere since my stop light fuse has begun blowing (so no stop lights at all). Can someone elaborate on how to get to the innards under the shifter stick where the pattern select switch, shift lock solenoid and other stuff lives? Do I have to take off the whole center arm-rest console thing? I have already taken off the center wood-grain thingy but I am stumped from there on. Any help would be much appreciated. TIA fsuguy :P Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted April 8, 2009 Share Posted April 8, 2009 IIRC there are 2 screws on the 1st gen shifter. Mine just spins right off! :D :D :D Quote Link to comment Share on other sites More sharing options...
fsuguy Posted April 9, 2009 Share Posted April 9, 2009 jcrome04, I pulled off the surround plastic piece from around the shifter and can actually see stuff now underneath the stick. Where are the two screws you mention? I have a sort of cover on the shifter knob (toward the console); do I take that off? Also, to eliminate the "sloppy" shift do I havta get under the car? Thx Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted April 10, 2009 Share Posted April 10, 2009 The two screws I'm talking about are on the shifter itself... the leather part... you put your hand on.. with the O/D switch... (IIRC) Quote Link to comment Share on other sites More sharing options...
fsuguy Posted April 11, 2009 Share Posted April 11, 2009 jcrome04, thx for pointing that out. I have a '92 and don't see any screws at all on the handle (shifter). I think they may be under a cover on the front of the stick facing the console, though(?) not sure. Sorry to be dense, but what is IIRC? Quote Link to comment Share on other sites More sharing options...
fsuguy Posted April 11, 2009 Share Posted April 11, 2009 Nevermind I think I got it - IIRC=If I Recollect Correctly (?) B) Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted April 11, 2009 Share Posted April 11, 2009 Of course they are under covers! Small...screw head sized plastic covers! The LS doesn't have exposed screws in the cabin! IIRC = If I Remember Correctly.. you got it! ;) Quote Link to comment Share on other sites More sharing options...
fsuguy Posted April 14, 2009 Share Posted April 14, 2009 jcrome04, Thank you...will try that and see what I get! Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted April 15, 2009 Share Posted April 15, 2009 Keep us posted B) Quote Link to comment Share on other sites More sharing options...
TheDonzLEx400LV Posted April 16, 2009 Share Posted April 16, 2009 Try this site http://www.lexls.com/tutorials/body/shifter.html Quote Link to comment Share on other sites More sharing options...
fsuguy Posted April 19, 2009 Share Posted April 19, 2009 Try this site http://www.lexls.com/tutorials/body/shifter.html Thank you for the link... will let you know how it turns out when I get down to the work! Quote Link to comment Share on other sites More sharing options...
