Window Regulator
scotte
try just searching for the window motor itself. you might not need the whole assembly (motor + the metal rack). most of the time it's just the motor went out. open up the door and see first.
buying the motor new or from boneyard is much cheaper than the whole thing.
Excellent suggestion, I assumed that there was a issue with the window tracks. If the tracks are in good shape then by all means just replace the motor. Make sure you check the auto parts stores, they carry replacement motors.
