davidmaltby Posted October 4, 2008 Posted October 4, 2008 I have put all the volume to the front speakers and the bass all the way down because when putting the sound to the perfect setting the is a huge static problem. What could the problem be?
IS400 Posted October 4, 2008 Posted October 4, 2008 Check the rear sub woofer speaker and see if it is torn or damaged. Most 400's have this problem eventually due to the location of the speaker/sub sitting in the roasting hot sun under the rear window. Just a guess, but good luck finding the issue.
davidmaltby Posted October 7, 2008 Author Posted October 7, 2008 Check the rear sub woofer speaker and see if it is torn or damaged. Most 400's have this problem eventually due to the location of the speaker/sub sitting in the roasting hot sun under the rear window. Just a guess, but good luck finding the issue.
jcrome04 Posted October 7, 2008 Posted October 7, 2008 From what I can gather from that.. I'd say one or more speakers are blown. Cheapest route would be aftermarket. OEM audio is very spendy.
