Performance Products For Rx300
ahdoman
You can get a bit better performance by using Sunoco 94 gas. The RX300 engine has a detonation sensor that automatically advances timing until it senses pinging. By using 94 octane gasoline, your engine will be retuned slightly. You can expect around 10 - 15 hp extra.
Try driving with regular gas and then when the tank is empty, fill up with Sunoco 94 and test drive. You will see that it seems much "peppier"
Hope this helps..
Dan
