Code P1300
grash
My check engine came on today I had the code pulled today. Its P1300 iginter circuit malfunction bank 1 or number 1. can someone tell me where is bank one. I had the iginter replace this summer still have the CEL on the car runs fine.
On either the 3VZ-FE or 1MZ-FE engine, as you look at the motor from the front, the cylinders in back by the firewall are numbered 1-3-5 left to right.
The front bank of cylinders are numbered 2-4-6 left to right.
When I first got my ES, I cleaned the engine and got water everywhere like a bonehead. Right after that I had a code saying the same thing but for cylinder #3 (center, rear)
That means Coil. There are six on this car. One right on top of each plug. Go to the Toyota dealer or on line. They're about $70 to $80 I think.
They're little coil packs at the top of the spark plug boot. All one piece. Very nice, but pricey. Also, pick up a plenum gasket while you're at it. I recommend changing that every time you take it off. You might want to get new plugs if you're anywhere near due for them since it's a whole production to get to those rears.
Good Luck!
