How Can I Tell If I Got A Blown Head Gasket?
Kingmag2006
If its an external leak, you'll hear the push of air around the bottom of the head when the engine is running. If its an internal leak, with the engine running and the rad cap removed, you'll see bubbling in the coolant. Someone with more experience on this issue may jump in with more info for you.
