Hello i just want you to help me have got a problem with my lexus gs 2008 so there is no sound everthing is working i mean raido cd dvd but no sound and even i can't control the volume.
I checkd the amplyfier it is working and all the fuses is ok.
yes but i'm not in usa i took it to local dealer they coulden't solve it
no i didn't modify it is factory car i mean i did't modify any electronic in this car it works for some while and then while i'm driving the car it loses sound even. Then i need to hpe that it will work after 4-7 hours :)
I would start by checking all connection on the radio and amp. Maybe a audio shop in your area can do the job.
so you want to tell me that i should open the touchscreen and check the cabel, as i alredy disconnected the amp from the laggugae compartment and connected again.
That would be the logical place to look. Before you do that, you may want to confrim that its not the amp that is failing intermittently. You will need special equipment to do that.
  • 1 year later...
Hi Lexus900
Did you ever fix the audio problem. I have a 2006 GS300 with the same issue. The audio just goes away and comes back on its own. I want to make sure that it is something sample before I take it to dealer and spend $1000
Thanks
