Looking to get some winter wheels size 17.
ES 350 wheels in 17's have the same bolt pattern as RX 17's.
The only difference is ES offset if 45mm and RX offset is 50mm.
Not much difference in 5mm.
Anyone see a problem with this?
I thought the RX offset was 35mm although the 400h might be different.
The RX400h can handle an offset range roughly from +35 to +42mm, while the ES can handle roughly from +36 to +45mm.
Stock on the ES350 is 17x7 and +45mm offset
Stock on the RX400 is 18x8 and +35mm offset
You'll probably want to crunch the numbers, for from what I know, it's 2mm over fitting... you may still have clearance and they may work, but not from what the specs say.
