Daniel N (Denmark) Posted September 6, 2008 Share Posted September 6, 2008 Hi guys I'm mounting Tanabe DF210 springs on my LS from 1993. They will be mounted on my factory struts.. What is your opinion? Will the struts blow within short time or? What is your experiences Thanks for any replies :) Daniel Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted September 7, 2008 Share Posted September 7, 2008 I did the same thing on my old 91, Tanabe DF210's on stock struts. Yes they will blow, mine did, but surprisingly the ride wasn't bad at all. It was still very very smooth. Here's a photo if it helps what you're looking for. Wheels were 20"x8.5" +40 offset, 6.3 backspace TSW Mondello's. Tires were Toyo Proxes 4 225/35-20s Quote Link to comment Share on other sites More sharing options...
Daniel N (Denmark) Posted September 8, 2008 Author Share Posted September 8, 2008 I did the same thing on my old 91, Tanabe DF210's on stock struts.Yes they will blow, mine did, but surprisingly the ride wasn't bad at all. It was still very very smooth. Here's a photo if it helps what you're looking for. Wheels were 20"x8.5" +40 offset, 6.3 backspace TSW Mondello's. Tires were Toyo Proxes 4 225/35-20s Do you mean the ride wasn't bad at all, after they struts blew? I'm just not sure if I want to risk it. Wouldn't the tire ride ON the fender if the strut blows, and damage the tire? Quote Link to comment Share on other sites More sharing options...
Blayd Posted September 8, 2008 Share Posted September 8, 2008 I have to assume he meant the ride was not bad before they blew. I would not be riding around on a busted strut. Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted September 8, 2008 Share Posted September 8, 2008 The ride was still very smooth AFTER my struts were blown. Of course not as smooth as good struts on 15" tires. But it never rubbed. Not ONCE. I could turn from lock to lock all the way 100% Now if I took a corner with the wheel significantly turned, it would rub since the compression of the suspension would cause the top of the tire to hit the fender. Quote Link to comment Share on other sites More sharing options...
sidekickLS400 Posted May 8, 2009 Share Posted May 8, 2009 The ride was still very smooth AFTER my struts were blown.Of course not as smooth as good struts on 15" tires. But it never rubbed. Not ONCE. I could turn from lock to lock all the way 100% Now if I took a corner with the wheel significantly turned, it would rub since the compression of the suspension would cause the top of the tire to hit the fender. did you replace the shocks? still have the springs? im thinking of ordering some for mine Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted May 8, 2009 Share Posted May 8, 2009 No I sold that car years ago. Quote Link to comment Share on other sites More sharing options...
