91 Ls400 Wiper Replacement
91ls400
The snow is falling here in Ohio and it looks as if I need some new windshield wipers. The wipers I have on my 91 ls400 now are just streaking the water so I cant see anything. What all do I have to replace, just the rubber part or the whole steel and rubber blade Does anyone have a suggestion for what wiper blades to get and how to install them?
I suggest you replace the rubber only, and you should get this from your Lexus dealer.
Each rubber strip has two flexilble stainless steel pieces on either side. Take some pliers and gently pull the old rubber out. Now remove both stainless steel pieces from the old rubber and insert them into the new rubber. Take the new rubber (with the stainless steel pieces) and gently insert into the wiper carrier arm. There are two projections at the end of the arm that nest into the rubber end of the wiper.
Hope this helps.
Dan
