Headlight Replacement/condensation '05 Ls430
LDan
Have had car 3 years. Noticed condensation in front driver side headlamp cover. Then low lamp went out. Fainted at cost of oem new lamp. They want $1500 to replace entire assembly!!!
Need HELP on DYI on lamp and how to keep moisture from getting inside cover!!!!! THANK YOU FOR ANY ADVICE/help!
Moisture probably got inside the cover from a small hole somewhere. You could try looking for a used headlight from a place like Graham's Auto.
To keep this from happening in the future, it would probably be a good idea to inspect the headlights for holes/cracks periodically. That way, if you find one, you can repair it before it creates a problem.
