Greetings, I just had my brakes replaced and now, during the final portion of braking, 10 MPH and below, the brakes sound like a squeegee wiping water off an almost dry glass window. As this is happening, it feels as if the brakes are loosing some of their effectiveness. The noise seems to be coming from the front. Thoughts? Thanks.
It takes a few hundred miles for the brake pad and the rotor surface to "set in" after they're changed. Give it some time, if it doesn't go away after you've put 750 miles or so on it you should take it back to whomever did the brake service.
