K28Marina Posted August 25, 2008 Share Posted August 25, 2008 I have a 1995 Sc 400 and have only one functioning remote key. If I buy a used remote from e-bay, what are the factors involved that would enable this remote to be programmed for my car. Also, can anyone detail how to do it? K28Marina Quote Link to comment Share on other sites More sharing options...
Tomj8 Posted August 25, 2008 Share Posted August 25, 2008 I have a 1995 Sc 400 and have only one functioning remote key. If I buy a used remote from e-bay, what are the factors involved that would enable this remote to be programmed for my car. Also, can anyone detail how to do it?K28Marina I had the same issue earlier this year on my own 1995 SC400.... it's a two step process for remote keys. FIRST: if you buy a key, it must be a "blank" so that it can FIRST be cut to your car's locks. If you buy a remote key that has already been cut, you must buy a blank blade for it from the dealer, and it will then have to be cut by the dealer. Call your dealer for the prices for a replacement blank key blade, and the key cutting. My recollection is it was about $75.00 for a blank and the cutting together. SECOND, the remote must be programmed by a Lexus dealer to enable it to operate your locks remotely. This carries a second charge, and may not be an operation that can be done while you wait. I was told I'd have to leave the key and pick it up the next day. As with most things Lexus, it was expensive. I believe the "programming" of the remote cost about $95.00 when I checked back in March....and may vary between dealers for all I know. Hope this helps. Quote Link to comment Share on other sites More sharing options...
