showster Posted August 23, 2008 Share Posted August 23, 2008 I have noticed the front passenger window sticks on the rubber gasket that lines the door frame. Anyone else have this problem? It causes a heck of a noise when you try to lower the window. Even leaves residual rubber(?) on the window. Tried everything to keep it from sticking with no such luck. It is a 2005 Rx 330. Quote Link to comment Share on other sites More sharing options...
pyroforyou Posted November 4, 2008 Share Posted November 4, 2008 I have noticed the front passenger window sticks on the rubber gasket that lines the door frame. Anyone else have this problem? It causes a heck of a noise when you try to lower the window. Even leaves residual rubber(?) on the window. Tried everything to keep it from sticking with no such luck. It is a 2005 Rx 330. I just bought a used 2004 rx and all the windows seem to have the residual rubber around the windows and they each make a noise when you open them. I was wondering if there is noise when you drive the car from the seals. Quote Link to comment Share on other sites More sharing options...
blk_on_blk Posted November 4, 2008 Share Posted November 4, 2008 Try wiping your windows down with a heavy coat of Rain-X... then run your windows up and down a few times, then buff your windows clean. See if that helps reduce the drag against the rubber trim/seal. Quote Link to comment Share on other sites More sharing options...
