Installed New Clutch, Now It Won"t Disengage?
Verbal
Ok, i have a 92' SC300.... this weekend i installed a ACT Stage2 clutch, now when i start it up and push in the clutch....it won't disengage.
Here is a little history on the clutch, it would slip real bad before and sometimes wouldn't shift/ go into gear.... i figured it was the clutch, which upon removal i found the stock pressure plate was FUBAR. I have bleed the clutch many times after the install, i also replaced the slave cylinder. I am thinking the master cylinder is the culprit. The pivot arm moves, but only about an inch...if that.
Any advice would be great.... TIA!
  • 3 weeks later...
